I always had an issue with the tail of these style designs it just doesn't seem like it will work in the real world.
I had an idea to improve and make it more useful tell me what you think about making the tail of the car accordion into itself making it easier to park... If it was electrically controlled that the back tail extends out when it is placed in drive only?
My initial thoughts on solving the tail would be a partial trunk that the tail extends from using a metal frame and a rubber type of material that pushes out
This would make for a very unique design I haven't seen before
Something for you to, play with if you want.
That is a very clever idea ! Thanks for sharing.
"You don't fail until you give up. You learn, and move on." - Christ
" Hypermiling is not going slow, it's driving with more intelligence." - UFO
I hope to get back into it and smooth it out more -- there needs to be a radius along the rocker panel; and yes there are several areas that need better smoothing. I'll have to XRef it into DataCAD X3 to measure the frontal area, too.
... tell me what you think about making the tail of the car accordion into itself making it easier to park...
The "accordion" part doesn't sound good to me. The pleats implied by that would be at least somewhat disruptive to air flow, which is pretty important on a boat-tail.
My thought was that the clear section of the vehicle that we see in the model could be hinged, and simply flip up. Since you'd only be needing to do that at very low speeds, that shouldn't be much of a hit on economy and it won't need to hold up to 65 MPH winds.
The joint could be faired over without too much difficulty, I think, and the construction might be simpler than going with the accordion design.
Here's a rough SketchUp model of an "ideal" streamline shape from Hucho:
It is three extrusions (plan, side and front profiles) that are subtracted from each other. I moved the front wheels back and widened the track, and moved the back wheels farther back and narrowed the track.
