10-03-2016, 10:57 PM
#11 (permalink)
The Lip
Alright got some plastic dip I ran out from other projects. Makes it pop a bit more, and I'm glad I got the nose down a little more without having to lower it yet. That is coming soon I hope.
Before the dip
After
10-03-2016, 10:58 PM
#12 (permalink)
Originally Posted by Ecky
Although it won't improve your fuel economy, there's an easy way to clean up your headlights.
I had a bottle of the lens clarifying compound in this kit:
https://www.amazon.com/Turtle-Wax-T-...fying+compound
What I did was sand my headlights with 1000, then 2000 grit to get the old yellowed clearcoat off, then put some of the polishing compound onto the back of a wet dish sponge and got them nice and transparent. If you don't put some sort of coating on them, they'll yellow again rapidly. I originally tried diluted spar urethane, and then later a non-yellowing spraypaint clear coat, but neither worked very well. I ended up buying a tube of opti-lens which worked great and has stayed crystal clear:
https://www.amazon.com/OPT-OPT-OLC10...ords=opti-lens
Original headlights:
Cleaned up:
You could, of course, buy new headlights, but my Insight doesn't have any aftermarket options, and new OE units would be ~$4-500.
Thanks I'll look into that. Mine are looking pretty bad.
10-04-2016, 07:58 AM
#13 (permalink)
I now use 303 to coat the lens. We'll see how that works over time. It's a sunscreen and dries clear.
The Following User Says Thank You to Joggernot For This Useful Post:
10-04-2016, 08:03 AM
#14 (permalink)
^ I used Meguiar's headlight protectant for a while, which is basically a sunscreen. The opti-lens is a bit different though, it chemically reacts and bonds with the plastic to form an extremely hard oxidation-resistant shell.
10-04-2016, 12:49 PM
#15 (permalink)
How long have you had it on. Reading some of the reviews from amazon it isn't lasting as long as they say.
10-04-2016, 01:20 PM
#16 (permalink)
Master Novice
I'm liking your ride, Comp. That new lip on the dam looks sharp.
You ain't the first guy to do that license plate trick, I chuckle every time I see one - it's a convenient little push in the right direction provided by the government. I just don't get the chance - no front plates in TN.
10-04-2016, 01:34 PM
#17 (permalink)
Probably about a year and a half now? The spar urethane clouded up in a few months, but I was still living in Florida at the time. There's not as much sunlight in Vermont.
EDIT: The tube is probably good for 20-30 applications though, so if/when it clouds up again, I'll hit it with some 2000 grit, polish, and recoat it. I expect it would probably take about 20 minutes if I don't let it go too far.
10-04-2016, 02:17 PM
#18 (permalink)
Thanks,
Next step is to get the whole car squatted down a bit. Thinking of doing a 2.5 inch drop I know it says three is preferred, but there is less involved with a 2.5. Plus I'll get that extra half inch in clearance for all the speed bumps I have on base.
10-17-2016, 08:47 PM
#19 (permalink)
Ok 2nd tank since the Holes in the rear bumper, and got 30.3MPG. The weather is getting a lot colder, and I didn't drive a lot of fully warmed up trips. Most trips were just to work which is a mile away. So she really never got to warm up and be efficient. Tomorrow I have to travel 160 miles to take a swim test so I will get really good highway MPG numbers with doing 320+ miles tomorrow. Best without the holes on a trip to Montana this summer was 32. I plan on blowing that out of the water.
10-18-2016, 04:24 PM
#20 (permalink)
Well I finally scored the piece I have been trying to get for the passenger side mirror. I'll be doing a DIY soon on it for the EP3. Anyways after about a month and a half of searching for either a trashed side mirror or the piece it bolts up to I got one. Now to wait for it to show up so I can get to work on deleting it.
