Old 11-19-2010, 07:55 PM   #21 (permalink)
90 day: 52.71 mpg (US)
90 day: 70.75 mpg (US)
90 day: 52.48 mpg (US)
Originally Posted by SuzukiSteve View Post
Im jealous of the 1500rpm at 110mph! Those are some TALL gears.
110 km/h
Old 11-19-2010, 07:58 PM   #22 (permalink)
1st generation (2003) Prius:
source: 2003 Prius
1986 Volkswagen Golf GTI (road conditions unknown):
source: http://www.fsec.ucf.edu/Pubs/energynotes/en-19.htm#2b (dead)
via: Speed kills: testing MPH vs. MPG in top gear - MetroMPG.com
Old 11-19-2010, 08:02 PM   #23 (permalink)
1996 BMW 318ti - automatic
source: 1996 BMW 318ti Fuel Economy
via: http://ecomodder.com/forum/showthrea...318ti-775.html
Old 11-19-2010, 08:14 PM   #24 (permalink)
It's good to do a speed vs. mpg chart for your car so you can track your progress over time with various mods.
From: http://ecomodder.com/forum/141036-post116.html
Blue = boat tail & taller gearing ; Orange = taller gearing; Green = original
Old 08-28-2012, 03:55 PM   #25 (permalink)
Adding to the pile:
from: http://ecomodder.com/forum/showthrea...2-a-21152.html
Old 08-29-2012, 08:23 AM   #26 (permalink)
The Mistress - '88 Bmw 320i Touring SE
Team m8
Last 3: 27.17 mpg (US)
Germany Beadle - '91 Mercedes 300td (estate, N/A)
90 day: 24.63 mpg (US)
The Bloodylingo - '05 Citroen Berlingo Multispace Desire
90 day: 39.77 mpg (US)
Shanner Scaab - '03 Saab 9-5 estate Vector
90 day: 26.19 mpg (US)
Clio 182 - '05 Renault Clio RS 182 182
90 day: 31.73 mpg (US)
I've taken a slightly different approach here..
I log the AVERAGE speed of my 328i per tank (usually 230-270 miles), and do tank to tank MPG comparisons..
I've plotted these in an effort to determine the best AVERAGE speed for LPG consumption.
In the chart below
Speed (MPH) is along the bottom
MPG (imperial) is up the side
The values attached to the data points are the MPG recorded at that speed
I'd be interested in your opinions and observations..
My Blog on cars- Fu'Gutty Cars
http://fuguttycars.wordpress.com/
US MPG for my Renault Clio 182
Old 08-29-2012, 10:27 AM   #27 (permalink)
It's interesting to noodle the graph...
But I'm not sure using average speed as a measurement over an entire tank works well as feedback to the driver unless the tank is predominantly highway/rural cruising, and other tanks results are over the same/similar route. (IE - controlling for as many variables as possible.)
EG: if a tank includes a siginificant mix of city/suburban plus highway motoring, how do you interpret the results & use the average speed number to your benefit?
Also: does the measurement of average speed include time stopped? (EG: the ScanGauge average speed calculation is not a "rolling" average, which would be more useful. Its calculation includes time stopped.
Consider too that spread out through the year, weather effects will affect the MPG numbers (cold weather = worse mileage; warm = better). How is that separated from the average speed variable?
Old 08-29-2012, 01:25 PM   #28 (permalink)
Team m8
The reasoning I decided to measure tank to tank average speed are as follows
1.My range is only 230-270 miles, circa 1 weeks driving
2.I have a basic commute of 250 miles a week- same routes at the same time of day. Therefore the majority of data was recorded on the same return journey
3.The car has a built in average sped function on the OBC
4.Variables I cant control are so large and vary so much over the course of a tank that they even out (e.g. so far this week I've had 2 dry partial commutes (one out, one back not on same day) and 4 wet ones) no to mention the temp going from 20 degrees to 9 and back to 14 in the same 3 day period.
Then there's the traffic and accidents...25 miles in 55mins today
The average speed figure represents (to me) a function of the above noted components, allowing me to guesstimate fuel costs, and review budgets. I can also check the average to see whether can afford a "spirited trip" home, or whether I have to be mega frugal
My ccars OBC counts it as "Key on" speed- essentially if stationary but at position II on the ignition, its calculating..
as above, I've decided that the Scottish weather its too much of a task for one man
Old 08-29-2012, 03:01 PM   #29 (permalink)
Mechanical engineer
Vekke's Avatar
Siitin - '98 Seat Cordoba Vario
90 day: 58.56 mpg (US)
VW Lupo 3L --> 2L - '00 VolksWagen Lupo 3L
Diesel
90 day: 104.94 mpg (US)
A8 luxury fuel sipper - '97 Audi A8 1.2 TDI 6 speed manual
90 day: 64.64 mpg (US)
Audi A4B6 Avant Niistäjä - '02 Audi A4b6 1.9tdi 96kW 3L
90 day: 54.57 mpg (US)
Tourekki - '04 VW Touareg 2.5TDI R5 6 speed manual
90 day: 32.98 mpg (US)
A2 1.4TDI - '03 Audi A2 1.4 TDI
90 day: 45.68 mpg (US)
A2 1.4 LPG - '02 Audi A2 1.4 (75hp)
90 day: 24.67 mpg (US)
Here is my Lupo 3L stock data on blue and some estimation on red dots.
https://fbcdn-sphotos-g-a.akamaihd.n...76622797_n.jpg
https://www.linkedin.com/in/vesatiainen/
Vesa Tiainen innovation engineer and automotive enthusiast
Old 08-30-2012, 09:39 AM   #30 (permalink)
Vekke - mind if I post that image in this thread?
The BSFC chart thread (post 'em if you got 'em) MetroMPG General Efficiency Discussion 302 05-03-2022 03:20 AM
EM Blog: GM engineers feel MPG gauges should be in all cars MetroMPG Instrumentation 2 10-24-2013 04:56 PM
2011 Ford Fiesta SFE (29 city / 40 hwy MPG US) Nels General Efficiency Discussion 68 11-29-2011 11:46 AM
Field Weakening Experiment for Speed Increase TomEV Fossil Fuel Free 12 04-10-2008 03:53 PM
EM Sticker contest #2: guess Mom's MPG! ('97 Camry 4-cyl auto) ends Sun., Feb. 3 MetroMPG Hypermiling / EcoDriver's Ed 33 02-04-2008 09:30 PM
