Old 05-06-2008, 05:54 PM   #1 (permalink)
Spray-On Insulation/Finishing Interior Surface?
Can anyone here recommend a spray-on sound insulation that can be used as the exposed layer on the entire interior of a car?
I'm interested in gutting out the interior of a Metro or Swift to lighten the weight of the car, but I still want to have some sound insulation and somewhat of a finish on the interior (for the significant other's sake at least).
Thanks for the help
Old 05-06-2008, 07:14 PM   #2 (permalink)
6 speed Diesel FTW!
The Golf - '02 Golf GLS TDI
Diesel
90 day: 63.94 mpg (US)
Mongoose - '05 E-bike AWD
90 day: 1810.34 mpg (US)
Send a message via AIM to dremd
Spray on Bedliner works well, but carpet glued on works much better for noise . . . . Worse for Water . . .
6 speed ALH TDI
Old 05-06-2008, 07:53 PM   #3 (permalink)
Thanks. I'm looking into bed liners now. One thing I'm concerned with is making sure whatever product I choose must have low levels of VOC. I mean I will be in a closed compartment with this stuff. I don't want to get sick.
Old 05-06-2008, 07:56 PM   #4 (permalink)
6 speed Diesel FTW!
Diesel
If you do bed liner DEFIANTLY USE A GOOD RESPIRATOR the stuff is POTENT.
I've used it on several interiors before, use a respirator, only spray for 3~5 mins, open doors, use a fan and you are ok. <- Not Official OSHA Advice
6 speed ALH TDI
Old 05-06-2008, 08:03 PM   #5 (permalink)
Good advice that I definitely plan to follow. But, I'm also concerned with this stuff continuing to offgas long after it has dried. If it contains VOC's I want to make sure it's at least at a low level. 150 gm/l or lower.
Old 05-06-2008, 09:20 PM   #6 (permalink)
6 speed Diesel FTW!
Diesel
I couldn't give you any specs, but I can say that it does not smell after 2~3 hours. . . .
6 speed ALH TDI
