Old 03-26-2009, 03:18 AM   This thread is in the EcoModder Project Library | #1 (permalink)
Pokémoderator
cfg83's Avatar
1999 Saturn SW2 - '99 SW2 Wagon
90 day: 42.23 mpg (US)
Spring mounted Grill Block
Hello -
(A moment of silence, please. Many zip ties were sacrificed to make this possible)
Like many of you, my car has a passive (doesn't move) grill block. That means it's a compromise between city and freeway driving. I also have an HAI, a Hot-Air-Intake. At city speeds this gets nice and toasty warm, but at highway speeds it typically gets cooler because of the increased air flow into the engine compartment. An active grill block could deal with this problem, but I don't want to spend a lot of time and effort on a control system that has a higher likelihood of failure. The main problem is I want an open grill block at city speeds and a "closed" grill block at freeway speeds. Right now I am trying this :
At city speeds, the coroplast "wing" stays in place. It is hinged in two places on the bottom and attached to the license plate via springs at the top. At highway speeds, these springs should stretch and close the lower radiator cooling vent. These springs are "C-7" springs that I got from OSH.
Here is a front view. The red lines show where the hinges are underneath the coroplast flap.
Close-up of the hinge. There are no holes drilled into the car. The diamond-grill is a rain gutter leaf protector that I used to slightly reduce the amount of air coming into the lower radiator cooling vent.
Close-up of springs.
Side view showing downward angle of flap. Sides of flap also bend down on the ends because the original coroplast had a bend to it. If you look closely, you will see a square piece of "packing sponge" that I am using to modulate the amount of air that gets into the upper cooling vent. As the weather heats up, that will probably be removed.
A while back, Frank Lee pointed out that this could suffer from "wing flapping", but I think I have accidently used the right springs for the job. If they were too strong I am sure that there would be flapping. I need to have someone watch my car on the freeway, but I haven't gotten around to that yet. I keep waiting for a shiny-butt gas truck, but they seem to be hiding from me.
When I originally used it, I had a grill block (pipe insulation) on the upper radiator cooling vent. Everything was fine when I was driving on the city streets. When I got on the freeway, IAT and coolant temperatures immediately started to rise and wouldn't go down. I see this as proof that I am getting a "dynamic" grill block effect on the highway. I pulled off the freeway and removed the upper grill block. This is a compromise. Normally you want to have the grill block on the upper cooling vent, and the opening in the lower cooling vent. I am not too worried about this compromise because my car has the "below headlight" cooling vent style of the late 1980's/early 1990's.
In this current configuration, I am seeing hotter IAT temps at freeway speed, at least 10+ degrees F more than I used to see. My coolant temperature also is up from 190 to 193+ degrees F, which I can live with. I think that as the weather warms up, I will need to keep tweaking it to keep that car's cooling happy. But, it's zip tie mounted and therefore 100% removeable, so I have no worries.
CarloSW2
American Solar Energy Society
Old 03-26-2009, 03:36 AM   #2 (permalink)
Dartmouth 2010
SVOboy's Avatar
Vegan Powa! - '91 CRX DX
90 day: 66.52 mpg (US)
Now have someone jog in front of the car on the highway and take pictures!
Really though, how will you know if it's working?
Old 03-26-2009, 10:34 AM   #3 (permalink)
aero guerrilla
Piwoslaw's Avatar
Svietlana - '05 307 SW
Diesel
90 day: 59.38 mpg (US)
Maybe some kind of one-way locking mechanism: once it lowers it stays there. Then you stop and see how far it closed at what speed and unlock it for another test. Of course, this locking device would be only be for testing.
Hmm, another option is to mount a pen on it and have and paper on the recieving end: if the wing closes, the pen makes a dot.
Then there's driving with a camera stuck to your bumper.
But the idea is simple, workable, and just plain AWSOME !!!!
Piwoslaw's Peugeot 307sw modding thread
Old 03-26-2009, 01:59 PM   #4 (permalink)
wagonman76's Avatar
Red Car - '89 Celebrity CL 4 door
Team Chevy
90 day: 36.47 mpg (US)
Winter Wagon - '89 6000 LE Wagon
90 day: 28.26 mpg (US)
You could tape some light gauge wire (light enough to not hinder the movement of the grille block, like maybe thin am/fm antenna wire) to both the spoiler and the grille block. Make sure the wires will easily touch when the grille block is closed. Maybe even use a small spring on one of the wires and tape the spring to the spoiler, like what is in the end of a battery case, that way the grille block won't have to be firmly bottomed out. Then run the wires to your dash, and connect them with an LED and appropriate size battery. The LED will come on when the grille block is closed.
Winter daily driver, parked most days right now
Summer daily driver
Old 03-26-2009, 03:29 PM   #5 (permalink)
Pokémoderator
cfg83's Avatar
Hello -
Ok, you are giving me ideas. I do have a wireless mini-cam I can mount in the fog-light area on the side. I will see if I can make this work for definitive proof.
CarloSW2
Old 03-26-2009, 05:33 PM   #6 (permalink)
Bio Deezler - '03 Jetta GLS TDI
90 day: 50.78 mpg (US)
nice!
Does it really function as a full grill block though? Looks like it would block most of the lower grill, but then also extend below the bumper and perhaps create unnecessary drag there?
maybe you could take a picture while holding it in the "on" or down position so we can see what it does in action.
Old 03-26-2009, 05:51 PM   #7 (permalink)
Pokémoderator
cfg83's Avatar
Deezler -
Good point. I will take a picture and post it later tonight ...
[time passes]
Here it is :
It does extend below the based of the lower intake vent. This is also maximum extension. I think I am ok because I think the rest of the "undercarriage" (old timey word) is lower :
I won't change it until I know how much it moves.
Tonight on the freeway my IAT stayed a toasty 145 degrees F while my coolant stayed at ~195 degrees F. In the past on a night like this I would expect sub-130 IAT and 190 coolant temps, so I am pleased with what I am seeing.
CarloSW2
Old 04-03-2009, 04:57 AM   #8 (permalink)
Pokémoderator
cfg83's Avatar
Hello -
Ok, I set up a webcam on the car :
This led to these pictures :
Notice the initial location of the spring and the license plate
As you can see in the picture, the spring is already very stretched out. Also, the license plate is "part" of the spring mechanism. It is only attached at the top, so it is being pulled in.
Here the spring is super-stretched out and the license plate cannot be seen.
Notes :
- The grill block works. It does "bounce" a little bit, but mostly in transition, not at steady-state speeds.
- The spring is too weak. I would rather have the spring hold it's own until the car gets over 40 MPH. This, however, will increase the risk of "bouncing" when the spring fights back.
- The license plate may need to be bolstered. I don't mind the license plate also "closing" the middle-section of the upper grill block, but I do want it to be more secure. There are only two plastic snap-in plugs at the moment.
- I need to make a YouTube of it in action. The first AVI I did was 900 MB, and I didn't get it with audio of me stating the MPH, so it was not postable.
Basically, it just needs tuning.
Me happy. Again.
CarloSW2
Old 04-03-2009, 09:48 AM   #9 (permalink)
Daox's Paseo - '97 Paseo
Last 3: 53.99 mpg (US)
Daox's Prius - '04 Prius
90 day: 57.08 mpg (US)
CM400E - '81 CM400E
Very nice! Glad to see it works.
Old 04-03-2009, 10:42 AM   #10 (permalink)
WonderWagon - '94 Escort LX
Last 3: 51.52 mpg (US)
DaRedOne - '99 Escort ZX2 Hot
DaBluOne - '99 Escort SE
90 day: 48.97 mpg (US)
Go ahead and use a stronger spring but add magnets to reduce/eliminate bounce.
Permanent Aluminum Grill Block and Belly Pan Markmysite EcoModding Central 37 12-20-2011 03:03 PM
Lower Grill Block 2005 Honda Civic Arminius EcoModding Central 12 10-04-2011 01:31 AM
96 Geo Tracker Upper Grill Block alohaspirit Aerodynamics 7 03-22-2009 01:05 AM
Airdam and grill block on the Mirage BrianAbington Aerodynamics 5 10-15-2008 07:54 PM
96-00 Civic Upper Grill Block Impulse Aerodynamics 2 07-12-2008 04:09 PM
