Old 01-12-2009, 08:16 PM   #11 (permalink)
Pushrod - '02 Cavalier
I would bet fuel economy is better at higher elevations. You get to open the throttle wider and the air hitting your frontal area is thinner.
Old 01-13-2009, 06:34 AM   #12 (permalink)
101% win
roflwaffle's Avatar
Camryaro - '92 Camry LE V6
90 day: 28.77 mpg (US)
Toy - '82 Pickup
90 day: 24.44 mpg (US)
roflwaffle: I didn't really do a lot of driving in the car. I did a couple of mostly rural trips in cold weather (-5 to -10C) that netted mid 40's MPG (US). Left to his own devices, my dad's mileage was 22.4 mpg in wintertime 100% sub/urban driving (from: Win an EM Sticker: guess Dad's mileage (Toyota Corolla automatic). Ends Jan 13. ). Not sure what he's getting on the open road.
Sounds like my grandpa. He has a 2002 and pulls ~25-30+mpg (~40/60 city/highway?) driving like everyone else in pretty nice weather.
Old 01-13-2009, 08:50 AM   #13 (permalink)
Blackfly - '98 Metro
90 day: 78.84 mpg (US)
ForkenSwift - '92 Metro EV
90 day: 81.72 mpg (US)
Revised graph!
Added the car's official highway fuel consumption ratings that also shows the constant speeds at which those figures were attained in these conditions.
Shows EPA "new", EPA "old" and NRCAN. I was surprised to see the Canadian rating so much higher - I was under the mistaken impression that they were nearly the same as the "old" EPA figures.
File Type: gif graph-speed-mpg-corolla-hwy-ratings.gif (62.8 KB, 269 views)
Latest project:
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
Latest test:
- fuel efficiency info for Geo Metro owners
- electric car conversion on a beer budget
Old 01-13-2009, 08:58 AM   #14 (permalink)
One of the things that surprised me about the car/graph was the point of best fuel economy at 40 km/h.
That speed happens to be pretty shortly after the transmission shifts into 3rd gear (of 4), so the engine is turning fairly slowly. It surprised me because it's the first speed vs. fuel consumption graph I've ever seen where the best performance isn't in top gear.
You can tell from the graph that the shift from 3rd to 4th (with torque converter lockup) happens between 60-70 km/h (shifts right in the middle at 65 km/h or 40 mph, actually).
It's possible to bleed speed down to 60 km/h and then hold 4th gear there, which would have raised that MPG point on the graph quite a bit, but I didn't. The transmission will downshift at the slightest prod under those conditions.
Latest project:
Latest test:
Old 01-13-2009, 07:17 PM   #15 (permalink)
Formula413's Avatar
Sleepwalker - '97 Firebird Formula
90 day: 20.14 mpg (US)
Spock - '92 VN750 Vulcan
90 day: 54.79 mpg (US)
03MX - '03 Civic Hybrid
90 day: 44.37 mpg (US)
Thanks for collecting and posting this data. This is motivating me to do a similar test for my car.
This sounds just like my car. There is a straight and relatively flat stretch of road about 1 mile long in my daily commute. The speed limit is 35 mph, I try to go just fast enough to get the TC locked and keep it there, which is about 37-38 mph (~60 kph) at just a shade under 1500 rpm. This requires a very delicate touch with the throttle, and careful monitoring of the TPS. On my way to work the car is not fully warmed up yet, usually just hitting the 150*F coolant temp required for lockup, and the road is very slightly uphill in this direction, and I see mpgs in the low 30s. On my way home the car is fully warmed up and has the slight grade working in it's favor, and I see low-mid 40s, as high as 50 mpg in warm weather with summer fuel.
More choices...
Old 01-14-2009, 10:05 AM   #16 (permalink)
Idiot Suv?? Sav?? Sev?? S
metroschultz's Avatar
SuperElasticBubblePlastic - '93 Metro plainjane
90 day: 55.06 mpg (US)
SilverHairBeauty - '01 Avalon XL
90 day: 24.06 mpg (US)
I'mL8I'mL8 - '99 Jetta GLS
90 day: 28.74 mpg (US)
Send a message via AIM to metroschultz
I was wondering if you would mention the TC Lockup between 60kph & 70kph.
I can force the TC to lock up in my wife's car at 55kph, by turning off OD then when I hit 55kph turn OD on. The trans will go straight to lockup, but as you said any extra load at this point drops it immediately out.
Nice work, Thanx,
S.
You can turn painful situations around through laughter. If you can find humor in anything - even poverty - you can survive it. Bill Cosby
Old 01-14-2009, 02:49 PM   #17 (permalink)
Ex-lurker
i_am_socket's Avatar
Skeeter - '05 Corolla LE
90 day: 34.6 mpg (US)
Graph looks about right. Too bad I can't get the "no traffic" conditions.
Good baseline info right there
I've noticed the best straight/level/low traffic MPG I can get is at about 33/34 MPH on one stretch of road near my house. Once in third gear it gets pretty high (needs-more-calibration 'Guino reads between 60's and 70's).
Old 01-14-2009, 06:41 PM   #18 (permalink)
Don't let me stop you. That would be interesting to see.
Oh - that's a neat trick! I didn't try that. It would sure save the extra energy spent getting to 65 kph just to get it to lock and bleed back down to a slower cruising speed.
Latest project:
Latest test:
Old 01-14-2009, 07:47 PM   #19 (permalink)
101% win
roflwaffle's Avatar
Toy - '82 Pickup
IME it's also more likely to lock-up at lower speeds if you give it a bit of gas, say going ~5mph above the lock-up speed, and then setting the cruise control as you let off the gas.
Old 01-17-2009, 11:50 AM   #20 (permalink)
Left Lane Ecodriver
Zombie Insight - '00 Insight MT
90 day: 55.13 mpg (US)
Phil: I wonder if we're seeing the slope of the Corolla graph getting less steep as speed increases to 120. That would be consistent with other graphs I've seen, eg:
( source: Speed kills: testing MPH vs. MPG in top gear - MetroMPG.com )
Where can I get raw data for one of these cars in the high-speed runs? I'd like to plot fuel consumption (gal/mi) versus speed and versus speed squared in the 50-85mph range, among other things.
How to get instant fuel consumption from Megasquirt TELVM Instrumentation 10 10-19-2009 06:28 PM
Tested: vortex generators (AirTabs) on a Toyota Corolla MetroMPG Aerodynamics 67 04-14-2009 04:44 PM
Review: 2008 Toyota Avalon Touring Edition (32.8 MPG) RH77 General Efficiency Discussion 2 09-04-2008 01:27 PM
Review: 2009 Toyota Corolla LE (37.9 MPG) RH77 General Efficiency Discussion 22 05-09-2008 04:55 PM
Win an EM Sticker: guess Dad's mileage (Toyota Corolla automatic). Ends Jan 13. MetroMPG Hypermiling / EcoDriver's Ed 51 02-07-2008 09:02 AM
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.3.2
