Old 02-03-2008, 02:51 AM   #1 (permalink)
DAN
too cold metro
someone posted about theirs. i need to dothis when I'm am more awake. forget the antifreeze. i know not about jap cars. but there must be a thermostat bypass. it lets water flow when the thermostat is closed. i can't see a manufacturer blow this, but if the bypass were too big it could pass too much water and keep the motor cold. look for a hose going from the water pump to the head. if all fails find the id of the hose and plug it. a small; part of it that is. . I'd find the id of the hose find a copper water pipe cap that goes in. drill it out say 3/4 or better, that's a big drop in flow, and see what happens.. but check the thermostat first.
Winter cold start & idling warm-up experiment MetroMPG Hypermiling / EcoDriver's Ed 17 12-17-2010 04:39 PM
Cold air VS Warm Air Intakes - what's the difference? deadman1474 EcoModding Central 48 11-15-2008 07:08 AM
Diesel Metro? michigandiesel EcoModding Central 17 10-16-2008 11:45 AM
MetroMPG.com mailbag: Metro engine won't stay warm in super cold weather MetroMPG General Efficiency Discussion 13 02-02-2008 12:28 AM
Radical Metro Aero Mods? Coyote X Aerodynamics 8 01-01-2008 05:05 PM
