Old 01-14-2008, 10:19 PM   #11 (permalink)
Giant Moving Eco-Wall
DifferentPointofView's Avatar
The Jeep! - '95 Grand Cherokee ZJ Laredo
90 day: 23.75 mpg (US)
The Caliber - '07 Caliber R/T
90 day: 30.6 mpg (US)
The 'Scort - '98 Escort LX
I tried to check my tire pressure the other day in my spare, but it wouldn't register on the gauge, it definitely had air in it, it just wouldn't hit the little valve button (forget what it's called) to let air hit the gauge and register. Anyone know of this type of problem?
Yea.. I drive a Jeep and I'm on a fuel economy site, but you just wouldn't understand... "It's a Jeep thing!" *Jeep Wave*
Did I Use Too Many Abbreviations? Here's The Abbreviations List
Old 01-15-2008, 01:50 AM   #12 (permalink)
Awesomeness personified
AndrewJ's Avatar
Harold - '94 Civic CX
90 day: 54.51 mpg (US)
Margot - '08 Big Dummy
Send a message via AIM to AndrewJ
I call that problem "Not having a dial-type pressure gauge"
I just hate the little stick-type ones, they're a pain to use even under the best circumstances.
"I got 350 heads on a 305 engine. I get 10 miles to the gallon. I ain't got no good intentions." - The Drive By Truckers.
Old 02-02-2008, 01:20 AM   #13 (permalink)
DAN
the stranded plug material is not safe. don't trust tire slime for stopping leaks. leiveng the screw in rips up the tire. go to a tire shope. if its a big hole (say from driveing around with a screw) they will put in a one pice rubber plug. if not its time for a glue on inside pach.
Old 02-02-2008, 01:41 AM   #14 (permalink)
101% win
roflwaffle's Avatar
Camryaro - '92 Camry LE V6
90 day: 31.12 mpg (US)
Toy - '82 Pickup
90 day: 24.44 mpg (US)
How is it not safe?
Old 02-14-2008, 03:51 AM   #15 (permalink)
DAN
tire makers say it sometimes pulls out. i don't know of any good tire shops that still use that way. it costs more to go to a tire shop to have put a rubber pach on the in side but its better. if its too big they have a tapered rubber plug that they glue up and pull throu rthe hole.
Old 05-08-2008, 11:43 PM   #16 (permalink)
Aspiring Eco-Modder
TheCivic - '99 Civic LX
90 day: 42.09 mpg (US)
Might just need a new valvestem core... Go to a tire shop and ask if they can give you a "new" one (like from an old valve stem they've replaced) and if you can borrow the core installer tool (kinda looks like a screwdriver, works the same way). Did this all the time when I worked in a tire shop
If you mean the screwdriver/t-handle and plug system by "stranded", then they are actually quite safe, many tire shops use them, and I have plugged many (as in 100+) tires with them (and did one of my own last week ). They are generally sold as "temporary" fixes, probably for the simple reason that the average person doesn't know much about plugging tires If the puncture is within an inch of the sidewall, or in the sidewall itself, the normal flexing of the tire will often cause a plug to leak. This applies to inside patches as well.
The problem with plugs is that many modern tires (especially low-profile tires) look fine on the outside when low pressure has caused them to actually melt down internally. The only way to be sure is to dismount the tire. Once you've gone to the trouble of taking a tire off the rim, you may as well spend 10 minutes boring out the puncture, cleaning the injury area, buffing it, applying cement, and then finally a patch/plug combo (one piece usually).
The problem with this method is that if the puncture is too big, the patch/plug won't work. Sometimes, if you do it right, 2 easy plugs will work... Sometimes, you buy a new tire
Old 05-13-2008, 09:48 AM   #17 (permalink)
lovemysan's Avatar
gutless wonder - '02 sl sohc
90 day: 40.17 mpg (US)
econoburban - '05 surburban 2wd LT
90 day: 19.43 mpg (US)
Plugs are illegal in some states I believe. I don't care though. I've been using them for 10 years. I don't even take the tire off the vehicle. If you work construction you won't have time to have every hole patched at a tire shop. One morning I went to my brothers house and put in 12 plugs and still needed 2 more. He'd been airing the tires up everyday to go to work.
I lost my reamer so I chuck a 3/16" drill bit in the cordless and ream it with that. You need a good pair of NEEDLE NOSE PLIERS with the plug kit or you won't be able to get the nail or screw out.
2002 Saturn SL
sohc + 5spd = 50mpg
mod pics see link below
http://s75.photobucket.com/albums/i3...emysan/saturn/
Real men have wheel skirts.
Old 05-14-2008, 01:36 AM   #18 (permalink)
Aspiring Eco-Modder
They are illegal in some states, one reason my old job switched from using them to patch/plug combos. And also 'cause people will put in 14 plugs into 4 tires I think after 2 plugs you're not supposed to plug em anymore (regardless of repair method )
DIY - Front Camber Kit SVOboy DIY / How-to 1 12-05-2008 12:52 PM
