Old 01-09-2011, 03:30 PM   #1 (permalink)
Mica Blue - '05 xA RS 2.0
90 day: 48.22 mpg (US)
Josepha - '08 xD
90 day: 30.76 mpg (US)
Vehicle Efficiency Improvements
Here's an updated list of my earlier blog post:
* The most obvious improvement to cars, would be to mold the plastic on the front of the vehicle to be smooth and round, with grill openings that are sized (and placed) only as required to cool the engine. Some new plastic bumper covers and grill pieces could be snapped onto cars. Flush covers should be used on all lights. Fairing pieces could be added to side mirrors. Hood gap gaskets, and streamlined wheel covers are easy, too.
* Sealing all the seams and joints (with gaskets or backing flanges) in the high pressure areas of the vehicle.
* Smooth floor pans with no sharp protrusions -- this is part of the drag just as much as the parts of the car that can be easily seen. Smoothing the underside with covers (like the EV-1).
* Transmission ratios should be optimized for efficiency at normal driving speeds. Higher gearing with 6-7 speeds would be optimal (smaller engines need more gears to work efficiently); or CVT transmissions.
* Narrower and lighter, LRR (low rolling resistance) tires should be used.
* Average & "instant" MPG displays, that are on all the time. The new Honda Insight, the 3rd gen Prius, and some Ford models, have excellent displays that help the driver be more efficient.
* Throttle control (rather than cruise/speed control!) that maintains even throttle in a user-set speed range, with minimal throttle increases to maintain the speed in that range.
* Use GPS and elevation data to "learn" more efficient throttle control, that could be used on the highway (for cruise control) and/or it could be integrated into a "throttle-by-wire" control.
* Tire pressure monitor, that warns the driver when the tires get below the recommended pressure (which could be adjusted upwards if the driver wants to run a pressure up to the tire sidewall maximum). Or better yet: fill tires with foam, so they would never deflate, and minimize rolling resistance.
* Efficient and effective fresh air flow through the vehicle, with intakes on a high pressure area, and exhaust vent(s) out the back of the vehicle into the low pressure wake zone, to reduce drag as much as possible.
* Coat all the window glass to exclude as much heat as possible.
* On defrost mode, the A/C should only come on automatically at maximum defrost (if at all), and it should always be toggled on/off by the driver. I would prefer to make A/C on the defrost setting optional, or have it use the A/C for a minute after the defroster is turned on -- and then it goes off automatically.
* Efficient lights such as LED's and HID, that use a little power as possible while functioning as well (or better) than incandescent lights.
* Lower consumption electronics, such as A/C, fans and audio systems.
* Active grill, that opens when more cooling air is needed, but remains closed – and is more aerodynamic most of the time. Or, a passive design that allows air through at low(er) speeds and then forces air to flow over the top at high(er) speeds.
* Use very low friction wheel bearings, such as ceramic bearings; along with low viscosity lubrication, to reduce rolling resistance. The VW 1L car uses these.
* Fully ducted engine cooling system, with the intake down low on the front, and the exhaust flows into a low pressure zone; minimizing the size of the radiator and the reducing the "internal" drag as much as possible.
* Video cameras and screens in place of side mirrors. This would help a lot with aerodynamics. An example of this starts with Post #167: Scion xA aero mods I also have another entry in this blog on this: http://neilblanchard.blogspot.com/20...-on-my-xa.html
* Automatic engine shut off and start up; at least with CVT (or automatic) transmissions -- and possibly with standard shifts, based on having both the clutch and the brake applied?
* Lean burn in low vacuum conditions. Use variable valve timing to gain efficiencies.
* Store hot coolant in a vacuum insulated tank, to speed up warm-up time; a-la what the 2nd generation Prius does. Or, do what the 3rd generation Prius does: heat the coolant quickly using the exhaust heat. Preheating intake air would also help fully vaporize the fuel; making it higher efficiency.
* Tighten up wheel openings, and always use aerodynamically designed wheels/covers, with rear wheel skirts (at least optional).
* Make roof racks removable. Years ago, I saw a "papoose" add-on storage system that locked onto the back of the car, with a single caster wheel to support the weight -- it tucked completely into the air flow behind the car; and it would be a great way to add storage space when needed; that did not affect how you drove very much. It could actually greatly improve the overall aerodynamic drag of the vehicle.
* An item that has indirect benefits: instead of thick foam and spring seats, they should be mesh or fabric stretched onto frames that provide the right ergonomic shape and provide good support without weighing so much, and taking up a lot of space. This allows a smaller and lighter vehicle because the size of car can be smaller and/or just have more room. Mesh seats would be much cooler in hot weather, and reduce/eliminate the need for A/C.
* Use hydraulic motors instead of brakes, so that the energy can be stored in a small accumulator, and then used to generate electricity to charge the battery (pack). This could be used in conjunction with the regenerative shock absorbers:
* Regenerative shock absorbers: MIT has a method of using hydraulics to drive a generator, eliminating the need for a mechanically driven alternator; or, to charge the electric drive batteries. These can also be used to lift and level the vehicle, to improve aerodynamics under different loads. Another enhancement would be to provide all the springing with the shock absorber; so maybe a pneumatic or electromagnetic unit would be better for this. There is now a company that makes regenerative hydraulic shock absorbers (each one has a little turbine that spins a generator!): Levănt Power
* Use a composite wheel/tire that has low weight, very low rolling resistance (by being strong enough to stay round), and low aerodynamic drag, no worries about inflation -- and re-tune the suspension to work with said wheel/tire. (see item above) This could gain even more energy, since very little would be damped by the tires.
* For new 4-cylinder internal combustion engine designs, the crankshaft could be split with a hydraulic coupling that can automatically disengage two cylinders completely; saving all the pumping and friction losses, for situations when 2 cylinders are enough to provide the required torque to move the vehicle. There are also cam-driven designs that about double the efficiency of the ICE.
* Nissan is (supposedly) going to reduce their cars weight by an average of 15%. I think all cars could be reduced by 20-30% with smarter steel fabrications, smarter use of materials. Here's a site that shows a steel chassis that is 25% lighter and nearly twice as stiff/strong as a conventional steel chassis:
BlueScope Steel Australia: Ultra Light Steel Auto Body (ULSAB) Project Multiple car door latches could be used to increase strength & safety of the chassis -- helps to further reduce weight, increase strength & rigidity, without requiring an unusual entry method.
* Use an EV drive train, combining batteries and a supercapacitor, and a "smart" controller, that makes use of GPS and elevation data, to use the supercap for the high current regenerative charging and short(er) duration acceleration, and/or to then charge the battery at a rate that does not stress them. In other words, using the supercap as an I/O energy cache, to reduce the requirements on the battery. This can either reduce the cost of the battery, and/or increase the battery lifespan and probably increase range; especially in high traffic urban driving or in hilly conditions. Driving on flat terrain at (more or less) constant speed probably will be more dependent on the battery, and less on the supercapacitor.
* Make every vehicle with a plug-in electric w/ serial hybrid ICE drive train, with regenerative braking. Use a cam driven engine that spins the armature and the stator in both (counter-rotating) directions, to charge traction batteries. The engine could have rotary valves to reduce parasitic losses. It would run at it's ideal RPM to drive the torque load of the alternator.
* Serial hybrids should use some of the energy near the end of the battery charge to run a block heater to warm up the ICE. Use the ICE coolant system to cool the electric motor, the electric controller, and/or the battery pack -- it would preheat the engine for start up & help to heat the cab reducing the need for electric heating.
* Rework the overall shape of the vehicle to reduce drag. Cd of 0.11-0.25 are achievable!
Last edited by NeilBlanchard; 01-31-2011 at 11:44 AM.. Reason: edited the defrost A/C item; fixed link to my old blog
Old 01-10-2011, 09:05 AM   #2 (permalink)
Josepha - '08 xD
I am particularly frustrated with the Prius on this: my Mom's 2007 has the GPS and the touch screen, and when you pull the A/C fuse to prevent it from coming on in defrost mode (full heat on the defroster is absolutely required during freezing rain / ice storms!) -- the entire HVAC system is completely disabled!
This totally rots... I think you can manually shut off the A/C, but remembering to do this and the fact that the touch screen toggles over to the default screen a few seconds after you stop using it, makes this much harder than it should be.
Old 01-10-2011, 04:29 PM   #3 (permalink)
The road not so traveled
TheEnemy's Avatar
The Truck - '99 Frontier xe
90 day: 25.74 mpg (US)
The Ugly Duck - '84 CJ7
Talking about light weight frames. Even with no crumple zones, and being massive overkill for a street car, this one at least features a 12 star roll over protection rating.
Old 01-10-2011, 04:56 PM   #4 (permalink)
...beats walking...
Old Tele man's Avatar
Vibe - '09 Vibe Base (2ZR-FE)
90 day: 32.19 mpg (US)
Goldie Locks - '011 Cruze LTZ
90 day: 29.42 mpg (US)
...GOOGLE: "Chenowith Dune Buggy" -- there should be something about their "updated" version "Rat-Patrol" vehicles for the military.
...we tested & used two of their vehicles at the U.S.Army Proving Ground, Yuma, AZ, back when I was working there.
