Old 05-01-2008, 06:12 PM   #1 (permalink)
Legend in my own mind
trikkonceptz's Avatar
Evil Pumpkin - '08 xD RS 1.0 #1633
90 day: 35.45 mpg (US)
Silent Silver Killer - '010 Insight EX
90 day: 51.5 mpg (US)
When to Fill up
I know I have seen threads that give the best time fill up ... empty vs 1/4 etc ...
However has anyone determined whether its best to fill to half a tank all the time or refill at the half way mark? Law of averages aside, I was wondering more about gas evaporation and whether or not gas evaporates faster in a tank that is half empty with obviously more agitation or mostly full, with less room for agitation.
Thanks ...
Thx NoCO2; "The biggest FE mod you can make is to adjust the nut behind the wheel"
I am a precisional instrument of speed and aeromatics
If your knees bent in the opposite direction......what would a chair look like???
Old 05-02-2008, 01:06 AM   #2 (permalink)
Blackfly - '98 Metro
90 day: 67.07 mpg (US)
ForkenSwift - '92 Metro EV
90 day: 125.37 mpg (US)
U.F.O. - '00 Insight
90 day: 85.75 mpg (US)
Gas doesn't evaporate from a modern vehicle. Fumes are captured and burned in the engine via the evaporative emissions system. So I don't think I'd worry too much about that.
Old 05-02-2008, 08:44 AM   #3 (permalink)
Good to know, thanks for the knowledge, now I can finally run a tank down and reduce the weight of half a tank ....
Old 05-02-2008, 09:29 AM   #4 (permalink)
Crapalier - '98 Cavalier
Thanks ...
Dont know exactly how the evaportaive emissions system works, but from a strictly theoretical standpoint, less gas in the tank will increase the vapor pressure of gaseous gas (more gas will be in vapor form in a half a tank than a full tank). From that point i guess you would have to figure out which system uses the gas more efficiently, the conventional system or the evaporative system
Old 05-05-2008, 08:11 PM   #5 (permalink)
Hi-Tech Redneck
Johnny Mullet's Avatar
Christine - '98 Metro Base
90 day: 62.59 mpg (US)
Send a message via AIM to Johnny Mullet Send a message via MSN to Johnny Mullet
Also running the tank low constantly allows an electric (in tank) fuel pump to pick up garbage and debris and may shorten fuel pump life.
Old 05-05-2008, 08:14 PM   #6 (permalink)
That concern is almost eliminated in these new compacts as they have sealed plastic tanks with no drains .... Fuel filters pick up any additional impurities.
mileage is mileage, right? (question about accuracy of small fill) Chris D. General Efficiency Discussion 16 10-21-2008 07:59 PM
Best Fill to date Pillzilla Hypermiling / EcoDriver's Ed 7 05-01-2008 04:21 PM
