I don’t know what you’ve all been doing over the holidays, but I’ve been working hard on EcoModder! I just rolled out a new theme today, so let me know in the comments what you like, don’t like, would like, or seems broken (I hope it’s all working), and I’ll adjust, 🙂
Popularity: 2% [?]
{ 1 comment }
It looks solid but there are some minor tweaks I think you could make. You need to add a carriage return after the google adsense block at the top of your posts, for example, the “I” is kind of stranded right next to it with the rest of the paragraph trailing.
Also, the right sidebar, you should either make the block have a gray background or turn that block into a white background. I personally think you should go with white and drop the vertical line. The line looks good for separation but people’s eyes will stop at that line (no joke) and your click thru rate on that ad will be lower with the line there (i’ve tested it).
Comments on this entry are closed.
