Originally Posted by cfg83
MetroMPG -
Great stuff. I want to see a close-up detail on the flexible spoiler lip. Does flexible mean it "gives" if it hits speed bumps?
CarloSW2
Almost all Vauxhalls/Opels have them over here in the UK. It's basically a cheap ABS plastic strip which doesn't stand out if you scuff it on something. Even so it's still about 15cm off the ground on standard suspension.
It's made from the same stuff as non-bodycoloured bumpers.
