Old 05-01-2009, 11:47 PM   #21 (permalink)
Allch Chcar
EtOH
Allch Chcar's Avatar
Cordelia - '15 Mazda Mazda3 i Sport
90 day: 37.83 mpg (US)
Cool
Originally Posted by evolutionmovement View Post
The manual rack will likely require more turns lock to lock, so keep that in mind.
If you need to increase the steering ratio for a manual rack in an ECHO of all things, you should consider electric powered steering. Increasing the turning ratio would be a bigger pain than going electric. For some people, power steering isn't a luxury item, for those efficiency minded people there is electric power.
If you know you can handle a power steering rack with the pump off, a manual rack with the same steering ratio is going to be a piece of pie. Even at the same ratio it's still easier to handle a manual rack.
Here's an article I found on electric power steering. And here. They're a couple hundred dollars from what I've seen. Hardly a good investment unless there is more than a 3% FE saving.
-Allch Chcar
