Old 02-18-2008, 12:20 AM   #10 (permalink)
RH77
Depends on the Day
RH77's Avatar
Teggy - '98 Acura Integra LS
Sports Cars
90 day: 32.74 mpg (US)
IMA - '10 Honda Insight EX
90 day: 34.76 mpg (US)
Tessie - '06 Acura TSX Base
90 day: 28.2 mpg (US)
Heated Intake
I had a '99 Acura TL that had a heated intake system. I'm not sure why, exactly, but it had a "mini-radiator" with a vacuum actuated door that diverted intake air over a coolant-heated device. My guess is that it heated the air on cold starts to improve emissions. To remove it (if you wanted) required a tie of the high-pressure coolant lines, or leakage would result. I haven't seen that on anything other vehicle, first hand.
I experimented by forcing the door open for a modified warm-air intake. On this particular vehicle, some malfunctioning sensors prevented an accurate test.
RH77
“If we knew what we were doing, it wouldn't be called research” ― Albert Einstein
_
_
