Old 05-06-2009, 01:09 PM   #27 (permalink)
COcyclist
Aero Wannabe
COcyclist's Avatar
TDi - '04 VW Golf
90 day: 52.55 mpg (US)
Arrow EGR helps TDI mileage?
Hi Tas,
So if I'm reading the last map correctly, in a modern diesel we want to lower O2 levels by adding more exhaust gas, and injection timing just a little before TDC for best fuel mileage right??
Many TDI owners eliminate the EGR with a block-off plate to reduce soot buildup. I have also read that some have suffered mpg losses in the process. Is it your opinion that a fully functioning EGR improves highway mpg?
If so, I may have to figure out an alternate location for a future EGT probe I'm hoping to install. (there is a nice kit out there with the thermocouple probe mounted in the block-off plate)
60 mpg hwy highest, 50+mpg lifetime
TDi=fast frugal fun
https://ecomodder.com/forum/showthre...tml#post621801
The power needed to push an object through a fluid increases as the cube of the velocity. Mechanical friction increases as the square, so increasing speed requires progressively more power.
