Originally Posted by dcb
That's correct, you should get an indication in gph. It may not be accurate until you get it .
Awesome; just needed that to test.
Looks Like Pin 66 on the 80 pin connector does the N146 (quantity adjustment) trick. It's a Brown and red wire; now off 2 find it.
Also working up a How 2 at the moment.
