I'm thinking that buying a generator may be more fuel and power efficient than buying an engine not intended for use as a generator and a DC motor not intended for use as a generator and coupling them. I also think that a rectified AC would be better or else your DC motor will be trying to turn over the engine when the engine isn't running (this could be solved with a bigass diode, though).
