I think a diffuser will help reduce drag. The air going over the car is high velocity/low pressure and the air going under is low velocity/high pressure. Thats what creates lift, and therefore, drag. If you can reduce that pressure differential by increasing the velocity of the air going under the car you should reduce drag.
