Old 02-19-2008, 08:44 AM   #31 (permalink)
brucepick
OCD Master EcoModder
brucepick's Avatar
Outasight - '00 Honda Insight
Gen-1 Insights
90 day: 54.18 mpg (US)
Originally Posted by tjts1 View Post
Hey Bruce
Quick question. What kind of plastic did you use to make your airdam and more importantly where did you find it. Did you put it together with rivits, nuts and bolts. Im dreaming up an undertray for the 850. I was planning to use aluminum but that stuff is getting expensive and hard to find.
thanks for the help
Justin
I like wood. Cheap to buy and easy to work. I used approx. 1/4" plywood for the airdam and 5.4 mm. lauan plywood for the undertray. More recently I used 2.7 mm. lauan for the 'grill' panel - I like the 2.7 mm. a lot. Get lauan at Home Depot etc. 2.7 mm. is $7.xx per sheet!
Folks can joke if they want about the plywood. Even without primer protection I had no rot problems due to lots of drying airflow. However, no primer = finish paint gets wrecked fast. I used oil base house primer on the grill panel and the primer survived winter's blowing road sand and everything else. Any new wood work will get that primer. I had them mix it as dark a gray as they would go. Too much pigment = not durable. I wouldn't use latex primer. Oil base is a lot tougher. Just doing small sheets, so I use cheap foam brushes and cleanup is not an issue.
The grill's dark blue finish coat took a beating though. Black pickup bed liner paint from Duplicolor has done very well on top of the primer when I put it on the air dam and in other applications. It's tough stuff, and cheap. I'm still looking for some tough clear protective top skin. I'm sure the bed liner (comes in black only) would hold up fine on the grill but I think it looks good in dark blue.
The 1/4 inch plywood strip for the lower air dam was a bear to bend. This spring I plan to build a new one of 2.7 mm. lauan.
I got a strip of aluminum angle stock and cut it to make angle brackets. That's what attaches the undertray to the lower air dam. I used stainless screws + nuts. Rust is a PITA, stainless ain't that expensive unless you want metric.
Next time I'm considering pop rivets instead of screws + nuts. Because you have to get at the back side to hold the nut, the undertray is roughly 1/2 inch up from the air dam's lower edge (for access to the nut). Using rivets I should be able to drill thru panel + bracket and then put the rivet in. So undertray can go flush at bottom edge of lower air dam.
Coast long and prosper.
