Old 05-14-2009, 10:38 PM   #3 (permalink)
bluesfan
bluesfan's Avatar
The Bluesmobile - '08 Mazda B2300 2WD
90 day: 22.62 mpg (US)
Originally Posted by FLYBYU View Post
In the past I've divided the liters by 4.54 to get gallons and multiplied my kms by .62 to get my miles then I divide the miles by gallons to get miles per gallon.
The 4.54 factor is for converting liters to British/Imperial gallons.
I posted a handy chart a few days ago that will give you what you need and more. Once you have the fuel converted to US gallons and the distance converted to miles, you can use the forum's fuel log feature to help you keep track of your MPG. I use the fuel log and a simple Excel sheet too. The chart -- courtesy of the CDN gubbermint -- is here:
http://ecomodder.com/forum/showthrea...tml#post103300
EDIT: Multiply the US MPG by 1.2 if you want the old familiar Imperial MPG numbers
In reverent quest of the last mpg...
