Old 05-15-2009, 09:51 AM   #14 (permalink)
MetroMPG
90 day: 51.82 mpg (US)
Originally Posted by Ryland View Post
running your EV dead is even harder to do then running your car out of gas, if you don't notice your gauge says you are running low on charge then you should notice that you are slowing down.
True for lead acid chemistry, but none of the new EV's will be lead sleds. And from what I understand, lithium (for example) gives full performance throughout its charge, then suddenly falls on its face at the end.
