Old 05-16-2009, 03:58 AM   #1273 (permalink)
MissileStick
Haha, full speed ahead then! I should hope that if you're DIYing your EV controller you'll use some common sense...
Looks good, and I'm beginning to see how it populates with parts! That's gonna be ace. It looks like you're doubling up on the capacitors, with two across each gap. Makes sense - it saves on cutting.
Keeping all the caps on the same side for this one? Good for you - symmetry is overrated.
