There are no plans for lowering my truck. I do off road it when I go out hunting, but that's only a few times a year. Where do you guys find the ScanGauge? Also, what does it work off of? My fuel sending unit doesn't work all the time and I can't just change the sending unit out. It's apart of the fuel pump also and that's about $500. If the scangauge works off the sender it won't be accurate.
