Old 05-18-2009, 09:22 PM   #6 (permalink)
MetroMPG
90 day: 51.82 mpg (US)
Wow - that's quite the trade!
My sister has one, which I've driven a bit, so I think I can tackle some of your questions:
Originally Posted by trikkonceptz View Post
Is it normal for the electric motor to whine when not in use? Once it is engaged through regen braking or in E Mode it goes silent.
I don't recall hearing the motor when NOT in use. But it definitely makes a very faint electronic whine when propelling or regen..ning.
-So far the best cruising range I have gotten from E Mode is 3 miles, is that normal?
That's sounds above average. I've read you can expect 2-3 km.
Keep in mind you'll get your best mileage, ironically, by minimizing use both of electric drive and regen. (Which requires some serious eco-driving effort.)
The batteries tend to discharge quickly when in E mode but recharge just as fast, therefore I'm guessing that is normal.
Sounds normal. EV mode is meant to be used sparingly though - repeatedly exhausting the battery will shorten its life.
Any tips on what I can do that will not permanently alter the vehicle?
I think I'd start with ... block heater.
