Yes, tyrereview.co.uk is user reviewed and they don't do actual tests, but the feedback from people are good general indicator of how a tire performs.
Originally Posted by Vekke
What you mentioned about the safety issue I think it is flushed to the toilet when/if? you pump your tires to 45 PSI.
Actually, my car's manual says for my model (ECO4) to pump the tires up to 41 PSI, and when under load, pump them up to 49 PSI. For all the other Astra models of the same shape, they recommend around 28-35 PSI including those with the same tire size as the ECO4.
Anyway. Cleanproxes E10 isn't in my size either. Where would I find aluminium wheels?
