Old 05-20-2009, 06:36 PM   #56 (permalink)
theunchosen
Originally Posted by hamsterpower View Post
Sorry to tell you the S80 transmission from the Integra LS will absolutely NOT fit you engine.
You do have other choices that are equal or better for economy with this engine. You have a D series engine so a transmission off nearly any other D series engine will work. and you will not need to change shift linkage unless you change your engine to a B series.
I'm not sure off the top of my head if you have a hydraulic clutch. That is the biggest issue you will have to watch.
Civic transmissions from the VX/HX have the tallest gears then the DX/LX are in the middle than EX/SI is the shortest and what you have most likely.
The civic and del sol with Beries engines are even shorter gears than you have now, in fact the Integra LS gears are shorter than the Civic DX listed above.
I'm not saying you are wrong I'm just asking are you sure? If I recall everything is just about the same. I can't find any photos to match up with at the moment and I nor my neighbor have an integra so I can't go out and compare. I worked on an integra last week and I was fairly sure they were the same packaging.
Different driveshaft coupling?
