Originally Posted by r3tic
Yes, they go into the ecu. I have run into another problem in that the injector pins are the 12v side of the signal. I really didn't want to go through the firewall but now it looks like I will need to in order to get the correct wire. There are about 5 different pinouts for the 6th generation of civics, if you need a different one than what I posted, let me know.
What did you end up doing, wiring to the ground side of the injector? Did it work? I'm about to install in a 99 Civic EX. Did you try wiring to the +12V injector signal off the ECU first? Thanks in advance.
