Originally Posted by MPaulHolmes
Holy hanna montana that's fast!
Well, it is just scheduling the adc conversions and returning. The adc conversions happen in the hardware and the main loop will march forward till the adc complete interrupt says ("OK, I read that last channel").
The top of the main loop halts interrupts briefly, makes its own copies of the interesting variables, then re-enables interrupts. It can't use the global versions directly because they could get updated in the middle of a computation.
Max ADC rate is about 10khz, and there is only one channel at a time, so a lot of the timer1 calls will auto-return, but it is what it is and the bulk of the processing (32 bit math?) can happen in the main loop outside of interrupts.
