Old 05-26-2009, 12:19 AM   #22 (permalink)
jtgh
you forgot to look again.
look at the drawing carefully, please.
see , if you remove the bulbs , you loose the normal function.
all cars are diff,diff models , and all countries have diff rules. (on lighting)
so you must get the drawings for a specific veh. before you can guess.
cutting the wire, or removing or cutting the bulb contact will kill all low beams for ever.
the DRL has 2 modes:
1: sends full power to the Low beams ( normal mode) " and a dark detector"
2: or it sends low power (voltage is less) to the low beam filaments.
that is how it works (plus some logic)l
look at the drawing and , it is exactly correct for 99 monte.
cheers/
PS: please dont drive on high beams for ever.
it could be bad for you. and others.
