Originally Posted by theunchosen
The Civics DRLs are a different bulb. Incorporating DRLs into your regular lights is assinine. . .it makes it far more likely to toast your truly needed actual low beams. . .
Except for the fact that GMs use the high beams for DRLs, not the low beams. That is, the ones that use the headlights -- some GMs use the turn signals.
