ok with all of my rechecking wiring, the hollow connector pin acceptor for the hot lead has broken off inside the connector. can i buy a new set of four pins and a connector for the pre-assembled mpguino? in other words the complete kit in the little bag that comes along with the unit. I have been using 16 gauge wire. I suspect that might be a little thick for this project. what gauge should i be using here? I did reset the check engine light. just before i broke the hot lead, I checked all of the connections individually. the light came back on while the fuel injector lead was disconnected. the light also came on when the vss was connected. I removed the hot from the unit and the check engine light went away for good. Any further suggestions?
Thanks,
Jim
