Old 06-03-2009, 10:47 PM   #34 (permalink)
dcb
needs more cowbell
dcb's Avatar
90 day: 96.29 mpg (US)
90 day: 53.56 mpg (US)
That will tell you if something is wonky with the guino, though the prebuilts are tested before being shipped.
if after swapping:
you get both gph and speed then ??? (loose connection?)
you get speed but no gph then probably the vss circuit tap is wonky.
you get gph but no speed then maybe guino speed circuit is wonky.
you get no gph or speed then please report directly to FAIL Blog: Pictures and Videos of Owned, Pwnd and Fail Moments
