Old 06-04-2009, 10:36 PM   #11 (permalink)
agabrielauto
This company do it this way :
This system would comprise three of our SR200.12 Power Generators ($675 ea.), one WC.12B Master Control Module ($195), two WC.12S Slave Control Modules ($165 ea.), and one WC.VR2 Voltage Regulator Module ($190).
The three generators would be mounted so as to be driven by a single engine (though multiple engines can be used) -- typically be means of a single serpentine belt pulley mounted to the engine's drive shaft. The individual output terminals of the three generators would be connected together and with our electronic controls perform as a single generator (though more efficiently since we produce much less waste heat during the generation process.
The total cost of the system would be $2740
Is there any way to do that cheaper?
