Thanks for the info Aerohead. You always come through with the good stuff. I got the hood sealed internally to the radiator support and the sides are "sealed" from the factory with sheet plastic using a pressure fit. In my other post I discussed the front tray. I think I am trying to over engineer it and I am going back to the K.I.S.S way of thinking. I want to leave part of the front tray open (or a cable actuated drop panel) for the low speed cooling that the blocks will remove. I also have a 12 inch electric fan that I am mounting parallel to the ground as emergency forced air. I rarely get stuck in city traffic but I also don't want to have to jump out during a rainstorm to remove a block due to high temps. As for the grilles I have I seriously doubt the upper is doing anything measurable towards cooling on this car. It is just too small. The supercharged model has even smaller openings than mine.
Another poster suggested I seal the gap beneath the upper grilles. I was actually going to leave that because its an engineered gap , this way I would still get some flow.
I guess the reality of all this is that it is time to get outside and start experimenting with all of these theory's..
Thanks everyone for all of your input!
Dean
1996 Pontiac Bonneville SE 3.8L V6
