ok ok ok ok
I know traditionally diffusers work vertically. Or in some cases, vertically and with the aid of the outward sweeping veins then the diffuser functions cross sectionally.
In this case I want to keep things simple, I want to work with only flat surfaces for easy vein application, and to keep it cheap and easy to make.. blah blah blah. Im only going to make it function horizontally. Flat surface, and veins.
Perhaps Im just an idiot.
Thank you for your input, I will plan on maybe using 7 degrees of seperation between the veins then.
I definitely need to get off my rear and build this stupid thing.
