Here's what I found, but all need an inverter
I swear, I found a 12 - 14.5v buck converter somewhere. I'll keep looking.
There are more 24-14.5 volt units around but that would mean another battery.
16 volt batteries and accessories:
993 - Powermaster 16V Battery Accessories
Someone makes a Li 16V battery for racing. Only $1999 special for you. (There are cheaper ones)
https://p10.secure.hostingprod.com/@...1536435320330c
Iota 110 to 13.5V charger/power supply
IOTA Engineering DLS Series AC/DC Power Converters and Battery Chargers for 12VDC Systems
Iota Regulated Battery Chargers
EVDL - Ruggedizing an Iota power supply for DC
C use
This link is to a DIY16v battery charger
Automatic 12V Lead Acid Battery Charger
I also thought of using an 18V cordless drill battery just for the coil.
I don't know if all that info will help or hinder. Seems like the cheapest way is probably the inverter/charger combo like I have. All readily available and cheap. I found a 750Watt inverter at a dewalt repair/clearance centre for $25. I got the 50A charger for $60 at the same place. I was using 35A to run everything last night.
Good luck.
Vortex generators are old tech. My new and improved vortex alternators are unstoppable.
"It’s easy to explain how rockets work but explaining the aerodynamics of a wing takes a rocket scientist.
