Originally Posted by stevey_frac
... I can't tell the difference in the first two shots. Great idea to do this though. The more air you have going over the radio, the less you you need to let through the openings in the front.
My thoughts exactly. It allows for a smaller opening in your grille block therefore better aerodynamics. Mind you Stevie, my radio is mostly off so i could block it up completely!
ollie
