Old 06-10-2009, 05:16 PM   #15 (permalink)
aerohead
fit
Originally Posted by QuickLTD View Post
OK so I went to cut out a template for my upper grille block.. It's not as easy as I thought. I taped brown paper to the hood and grille and then cut it out. I then transfered the patern to some foam core poster board I just happened to have. I then test fit it and it. I am not satisfied with the fit. Does anyone have a better Idea? I am trying to get it to fit the contours of the factory grilles so it looks like it belongs there
QuickLTD,there might be some fabrication tips at the DIY / How To forum.I've never worked with the coroplast so I'm no help.But it seems like if you get a good paper pattern,and transfer it to the plastic,you should be within striking range of the shape.
