Originally Posted by hondo434
Doax, Thank you for your reply. I have stated I would remove the magnet to see if there is a difference in milage. I am just as interested in making sure that the magnet is the source. If you have any tests you want me to do I would be glad to try. As the magnet is a small investment it is not worth doing expensive outsourced tests to prove a point.
Hondo434, an objective way to prove gains is to log your OBD-II data without the magnet and then log OBD-II data with the magnet. You can use CarChip to log your data. Carchip has software to export these data. Once exported the data can be further analyzed and compared "OBD-II Data Easy Viewer". Google this text "greenfuelbooster OBD-II data easy viewer". I wrote the program and made it free for download. It will show exactly the difference.
