Old 06-13-2009, 01:22 PM   #68 (permalink)
dcb
needs more cowbell
dcb's Avatar
90 day: 96.29 mpg (US)
90 day: 53.56 mpg (US)
Originally Posted by theycallmeebryan View Post
Running longer gearing like this doesn't "generate less horsepower".
It probably does make a lot less power than peak, but is more efficient at converting any fuel given to it into power, look at a typical bsfc chart:
Peak power for an engine is where torque*rpm is at a peak, probably up in the 5000 rpm range, but peak efficiency is where fuel consumption/power is at a minimum, around the 2500rpm range and 3/4 available torque.
Edit, also could use better understanding of the gearing change implementation too please.
