Old 06-21-2009, 02:03 PM   #1770 (permalink)
jimini
Controller, motor combination.
Would the cougar controller be a good controller for this motor? Another question, would this motor be a decent motor for an ev conversion?
Sorry if i'm off topic here. Jim
GE 8" Series wound Dual shaft motor
SPECIFICATION:
· 43 HP at 120 Volts DC ELECTRIC MOTOR · 34 HP at 97V with 5,700 RPM approximately
· 25 HP at 72V with 4,200 RPM approximately
· 17 HP at 48V with 2,800 RPM approximately
· 7,000 RPM approximately at no load and 120 Volts DC
· 300 Amps full load at all voltages
· Ball bearing
· Rotation reversible
· Double Shafted
.Front Shaft 1” Diam. X 2" and tapers to 13/16"
.Rear Shaft 1" Diam. X 4" approximately
· Size 8.25” X 20” including shaft approximately
· Shpg. 145 lb estimate
