Originally Posted by alohaspirit
you are right as some people arent satisfied with the light output
although i think someone found a way around the fog problem by using some sort of polish to eliminate the reflection inside the lexan
some guys on this forum liked the way it turned out and said its better than stock
Headlight conversion like this one? - MX-5 Miata Forum
its basically a geometry debate
but you could always add fogs
I have some posts in that thread.
I came up with an idea of my own-- put the projectors in teardrop shaped pods mounted on aerofoil shaped stalks. They'd be high, for good light distribution, and because of the distance from the body they wouldn't spoil the airflow.
