Old 06-22-2009, 03:50 PM   #11 (permalink)
QuickLTD's Avatar
Flying Brick - '96 Pontiac Bonneville SE
90 day: 23.57 mpg (US)
Send a message via AIM to QuickLTD Send a message via Yahoo to QuickLTD
Probably the weight.
1996 Pontiac Bonneville SE 3.8L V6
Old 06-22-2009, 03:59 PM   #12 (permalink)
Remove half the cockpit to make a 1+1 and extend the tail.
Old 06-22-2009, 04:21 PM   #13 (permalink)
basjoos's Avatar
Aerocivic - '92 Honda Civic CX
Last 3: 70.54 mpg (US)
AerocivicLB - '92 Honda Civic CX
90 day: 55.14 mpg (US)
Camryglide - '20 Toyota Camry hybrid LE
90 day: 65.83 mpg (US)
An air dam is just an aerodynamic band-aid to divert air away from non-aerodynamic parts of the car (the rough underside). You can get a lower Cd by installing a smooth underpanel and allowing the air to flow straight and smoothly under the car rather than by installing an air dam and diverting the air around the sides of the car. The only reason to install an air dam would be to increase downforce (produced at the expense of increasing the drag) or if you didn't want to install smooth underbody panelling. None of the ultra-low Cd vehicles use air dams. They all have smooth undersides and, in many cases, have a lot of ground clearance to allow the air to pass under the vehicle with minimum disturbance. A low-flying aircraft fuselage suspended on wheels rather than a limpet scooting across the ground shoving everything out of the way.
aerocivic.com
Old 06-23-2009, 10:08 AM   #14 (permalink)
Sipper - '98 Volkswagen Jetta
90 day: 40.57 mpg (US)
Crusher - '01 Ford F350 XLT
90 day: 18.06 mpg (US)
Aloha: Please send link to the headlight conversion you mentioned
Wink: The seals are dry rotting on the sunroof and it's real noisy and I want it gone before it starts to leak. That , And I do not wish to pay what Nissan wants for new seals and such.
basjoos: thanks for the input, I did put in the airdam as a bandaid because it was much quicker and easier for now than to fab up the underpanel. I do have some suspension components that hang down lower than the lowest point on the nose and I started to make and underbelly but when fitting realized that there was about a 2inch gap that would slope downward and create lift on the front end if did that without somehow leveling it. I will post a pic so you can see what I mean.
Old 06-23-2009, 10:49 AM   #15 (permalink)
Bicycle Bob's Avatar
Last 3: 42.35 mpg (US)
Front air dams are popular in racing because they are easy to build, and reduce drag and increase downforce. On the street, they are popular for a racy look. For the best economy, you want smooth flow under the car as well as over it. The venturi effect can still neutralize lift.
Old 06-23-2009, 01:45 PM   #16 (permalink)
Grasshopper
alohaspirit's Avatar
Makai - '01 Toyota Echo 4D Auto
90 day: 34.45 mpg (US)
New Galaxy - '07 Toyota Prius
90 day: 42.15 mpg (US)
i did a quick search
came up with this style for $200
its import cool but price wise your better getting hellas and making a lexan cover
1989-1994 NISSAN 240SX S13 HALO HEADLIGHTS HEAD LAMPS - BLACK 89 90 91 92 93 94
Past Present Future?
Old 06-23-2009, 03:07 PM   #17 (permalink)
Alohaspirit, are you talking about the 50mm Hella projectors?
I doubt you'd get good light from Hella projectors under Lexan sheets, because they'd be too low in the body. It's a common problem with Miata headlight conversions- the light can't go downward enough.
Old 06-23-2009, 04:17 PM   #18 (permalink)
Grasshopper
you are right as some people arent satisfied with the light output
although i think someone found a way around the fog problem by using some sort of polish to eliminate the reflection inside the lexan
some guys on this forum liked the way it turned out and said its better than stock
Headlight conversion like this one? - MX-5 Miata Forum
its basically a geometry debate
but you could always add fogs
Old 06-23-2009, 04:55 PM   #19 (permalink)
I have some posts in that thread.
I came up with an idea of my own-- put the projectors in teardrop shaped pods mounted on aerofoil shaped stalks. They'd be high, for good light distribution, and because of the distance from the body they wouldn't spoil the airflow.
Old 06-23-2009, 05:08 PM   #20 (permalink)
Cd 0.19
Ditto on the whole meal deal.
aero mods-data-% change or Cd change ( installment # 7-Wheels/Tires/Wheelcovers/etc. aerohead Aerodynamics 5 06-04-2014 12:14 PM
Stitch away an aero cover! botsapper Aerodynamics 21 06-16-2013 12:02 PM
CRV Cross Country Trip Aero - Temporary Aero Just for the Trip walteraxe Aerodynamics 26 01-05-2010 11:37 AM
Aero Help On A Body Design Hasbro Aerodynamics 19 05-06-2009 06:08 PM
Another Autospeed aero article: methods for measuring aero drag Daox Aerodynamics 4 02-14-2008 12:34 AM
