Hey Joe! You are doing PCB layout! awesome! This is so exciting!
I got the money necessary for the fancy caps for Ben's controller from wherewolf and watt-a-mezz! Yes! No compromises on this one, Ben! (well, the aluminum heat spreader. hehe)
Thank you wherewolf and watt! I'm going to order them from Digikey. Also, the 2 control boards came last night! I need to add a couple components today to the boards, like voltage spike suppression diodes to protect the mosfets' gates.
