Old 06-23-2009, 09:43 PM   #1801 (permalink)
PaulH
MPaulHolmes's Avatar
Hey Royal! That would be great! I have the drawings of the bus bars, but they were chosen based on the free copper bars I got from wherewolf (on ecomodder, not a real werewolf). I think there are a few modifications necessary. I'll try to come up with what it would be in general. Drawings for the heat spreader, and for the bus bars. Thank you!
Thank you, Watt-A-Mezz! Now, if anyone wants to buy them from Digikey and have them shipped here, I can send that person over $17.00 from Paypal to offset the cost of the caps. When I add the poly caps, that will increase the ripple current by 5 amps per poly cap, so maybe that would make everything fine with the 470uF caps?
I think I'm going to use the 470uF caps with 3 of the polypropylene caps, which add about 15 amps of ripple current ability.
kits and boards
Old 06-24-2009, 02:58 AM   #1802 (permalink)
Paul, what size are those polypropylene caps? that,s a lot of ripple current per cap; Ive been looking at aluminum caps at over 1000MFD to get that level of ripple current absorption.
"Experience is something you get right after you need it !"
http://www.diyelectriccar.com/garage/cars/143
http://www.diyelectriccar.com/forums...tor-32083.html
Old 06-24-2009, 03:07 AM   #1803 (permalink)
PaulH
They are 4uF 250v (tiny, huh! But they look huge!). Their esr is very small, and they are excellent at absorbing voltage spikes. I don't know why they increase the ripple current so much. Maybe because they smooth out the spikes, it makes it easier on the aluminum electrolytic caps. Here's a picture of 4 of them:
kits and boards
Old 06-24-2009, 12:34 PM   #1804 (permalink)
Joe
Not sure if you were really looking for an answer, but this is what i've gleaned from discussions on the EVtech and EVDL.
I think it has to do with temperature - too much heat generation causes the temperature of the caps to rise which decreases their expected life. lower ESR means lower heat generated, so you can pull more amps from it.
Apparently one of the reasons using many smaller caps have a higher combined ripple current rating than one large cap is because the larger surface area. More surface area means the caps are easier to cool. cooler operation means more ripple current capability.
Like you, I've decided to add a couple of low ESR caps (film, i think) to my charger design. i'm still in the process of laying everything out on a PCB, but i hope to have results soon!
Old 06-24-2009, 01:04 PM   #1805 (permalink)
PaulH
Hey Joe! You are doing PCB layout! awesome! This is so exciting!
I got the money necessary for the fancy caps for Ben's controller from wherewolf and watt-a-mezz! Yes! No compromises on this one, Ben! (well, the aluminum heat spreader. hehe)
Thank you wherewolf and watt! I'm going to order them from Digikey. Also, the 2 control boards came last night! I need to add a couple components today to the boards, like voltage spike suppression diodes to protect the mosfets' gates.
kits and boards
Old 06-24-2009, 01:20 PM   #1806 (permalink)
Joe
I agree! i figured the cutting board and web-o-wire mess was way too amateur. now that my components are pretty much nailed down, I think we can be a little more professional!
Old 06-24-2009, 01:26 PM   #1807 (permalink)
slurryguy's Avatar
No music to go along with your capacitor conga line?
Old 06-24-2009, 02:43 PM   #1808 (permalink)
Black Panther,
Here's there thread. I'll respond there.
http://ecomodder.com/forum/showthrea...rger-8828.html
Old 06-24-2009, 03:17 PM   #1809 (permalink)
Wow that's impressive for such a small uF.
Something I am confused by; I would think that ESR and ripple capacity would directly correlate to each other for the same ratings on voltage and MFD capacity, but looking at numerous data sheets, it seems that they don't?
I must be missing something here.
I think you are right though about the spikes, I think that these are better suited to handle squelching the high frequency harmonic ringing from switching, and the higher capacity aluminum caps are better suited for smoothing the ripple from the root switching frequency.
Now I am rethinking about my capacitor order for my set up.
I am curious, is there a guide line for a ratio between controller current capacity and its capacitor bank ripple capacity and it's total MFD capacity? th would be so helpful.
I have a felling that I am going over board on MFD capacity and maybe a little low on ripple capacity.
Old 06-24-2009, 07:06 PM   #1810 (permalink)
PaulH
The copper pcb, bus bar, and top of heat spreader tinning is going very well! ya! A big gust of wind came by and blew a few leaves in the mix, but oh well (I'm outside). It's still working really well! The mixture has to be hot, so I have a space heater thing from costco that I have beaming at it. hehe. A stove or something would be nice, but mother in laws get scared by chemicals sometimes.
kits and boards
Paul and Sabrina's Cheap 3 Phase Inverter (AC Controller) with Field Oriented Control MPaulHolmes Fossil Fuel Free 3431 05-04-2022 06:43 PM
Paul & Sabrina's Cheap EV Conversion MPaulHolmes Fossil Fuel Free 542 11-12-2016 10:09 PM
Three Dirt Cheap DIY Electric Cars - Part 5 SVOboy EcoModder Blog Discussion 0 12-12-2008 05:10 PM
