Old 06-25-2009, 01:58 PM   #25 (permalink)
Christ
Moderate your Moderation.
90 day: 45.22 mpg (US)
+2 to DCB - Even if you used a governor plate, it would just increase resistance, the opposite of what you're doing with the hot air.
The only positive part of a governor would be that you could effectively re-set the 100% throttle position (in the case that there's a new driver behind the wheel, for instance).
Basically, the governor would choke out air supply, so that after a certain throttle position, no more air could get in anyway, so while the pedal wouldn't really be to the floor, it would still be at 100% of available throttle.
