"turning off" alternator
a buddy of mine suggested that if the alternator relies on a field wire to charge (like most of the VWs through 2001?), you might be able to relay or "switch" that wire so you can turn on and off charging. You will still have the momentum of rotation, but loose the physical drag of charging.
-Edward
Driven on Colorado roads, where NOTHING is flat
Present City 3x / Highway 4x
Goal: 4x / 5x
