Old 06-25-2009, 09:09 AM   #11 (permalink)
Some cars actually have this stock. I've seen it happen to my own shock. It looked like the alt was turning and then I noticed the end cap of the alt was sitting still and then it engaged and everything was turning like normal. Then after maybe 2 minutes it disengaged again(was recharging the AC).
I was pretty impressed but I can't recall who did it.
Old 06-25-2009, 10:36 PM   #12 (permalink)
90 day: 54.57 mpg (US)
90 day: 64.86 mpg (US)
Clev: no dash lights comparison. Didn't occur to me, but I'd have to guess it's less than 20 watts for this car between high & low.
theunchosen: I agree about solar being an occasionally viable option with electrical load being this low. Also agree about the cost/aero challenges.
Old 06-25-2009, 11:01 PM   #13 (permalink)
Jalilah - '07 Chevrolet Cobalt LT
90 day: 40.57 mpg (US)
... Perhaps i'm crazy... but... couldn't you recoup a lot of that juice with a system similar to this:
http://www1.eere.energy.gov/vehicles...eer_kushch.pdf
Old 06-25-2009, 11:21 PM   #14 (permalink)
McTimson's Avatar
Maverick - '22 Ford Maverick XLT
90 day: 36.81 mpg (US)
Very interesting results! I'm surprised that the high beams only added 8W, I thought that would be a lot more. This will definitely make me think about what I keep on when I EOC.
stevey_frac, from a quick glance, it looks like that system would definitely provide enough power when the engine is on.
Old 06-26-2009, 02:33 PM   #15 (permalink)
Manic Rabbit
Southcross's Avatar
Slow-n-Low - '81 Volkswagen Rabbit S
90 day: 33.97 mpg (US)
"turning off" alternator
a buddy of mine suggested that if the alternator relies on a field wire to charge (like most of the VWs through 2001?), you might be able to relay or "switch" that wire so you can turn on and off charging. You will still have the momentum of rotation, but loose the physical drag of charging.
-Edward
Driven on Colorado roads, where NOTHING is flat
Present City 3x / Highway 4x
Goal: 4x / 5x
Old 06-26-2009, 02:41 PM   #16 (permalink)
Thats exactly what I did with my alternator disable switch. Check out the Paseo build thread in my sig.
Old 06-26-2009, 04:40 PM   #17 (permalink)
thermo-electric conversion units are all rather expensive for performance. I would toss that.
The regenerative suspension and solar ought to be enough to entirely negate an alt during the day and if the single battery were replaced for two deeps you could run it at night for trips less than a couple of hours(objective is to keep the deeps from dropping below 80% charge otherwise you cut into their lifetime and the suspension regen ought to be able to slow it to allow maybe an hour and a half).
Old 06-26-2009, 06:28 PM   #18 (permalink)
Moderate your Moderation.
90 day: 45.22 mpg (US)
I like the suspension regen idea... links?
Would there be a way to make a shock that could be stiffened/softened by electrical load? (You could adjust it with a rotary pot for stiffness, and stiffer = higher output?)
Old 08-13-2009, 09:53 AM   #19 (permalink)
FYI, I had someone ask how to use a digital multimeter to get current readings for his particular car. Posted this thread:
http://ecomodder.com/forum/showthrea...amps-9642.html
Old 08-14-2009, 03:00 PM   #20 (permalink)
jedi_sol's Avatar
2013 STi *SOLD* - '13 Subaru Impreza WRX STi
Subaru
Sports Cars
Team Turbocharged!
90 day: 26.59 mpg (US)
1996 Geo Metro *RETIRED from Ecomodding* - '96 Geo Metro Base
90 day: 58.68 mpg (US)
I'm trying to plan how big of a solar panel/deep cycle battery is needed for my system. Here are my readings. They seem a bit high? Does anything seem off? (In terms of my testing procedures or my results)
Here is how I tested my system to get AMPS.
1) Engine Off
2) Disconnect + battery cable
3) with DMM on AMP mode, hookup +probe to +battery cable, -probe to +battery post.
4) Turn key to ACC ON
To get AMP readings for the engine idle, I disconnected the DMM, started the engine, disconnect battery cables, and hooked up DMM on AMP mode.
To get voltage readings, put everything back to normal, put the DMM back to voltage mode, re-did all of the accessories tests, and noted the voltage drops.
Recalculated
Standby (ACC ON after fuel pump primed) -- 12.1v -- 4.68amps --56.6w
Parking light, dash lights high --54w
Head light low, dash lights high --91w
High beams, dash lights high --100w
Brakelights only -- 48w
Reverse lights only --37w
Stereo volume 0 --4w
Stereo volume 30 -- 4.6w
Stereo volume 40 --6.4w
Fan Low, Interior -- 29w
Fan Hi, Interior -- 107w
Engine Idle --14.2v --6amps -- 85.2w
Engine 2500 --14.4v --6amps -- 86.4w
Thanks for your help!
See the rest of the Sti project log:
http://ecomodder.com/forum/showthrea...log-26612.html
