Old 06-27-2009, 09:43 PM   #4 (permalink)
Christ
Moderate your Moderation.
90 day: 45.22 mpg (US)
The 'burg has a built in alternator, right?
It probably only produces about 10-20 amps, max.
For posterity, the one on my tractor's engine is built in (it's part of the flywheel). It takes about .6 HP to make 15 amps @ 12VDC. (According to Briggs, IIRC)
15*12 = 180 watts
Assuming 50% efficiency, 180 watts takes about .5 HP to make, the rest of the power loss is heat, I presume.
If your 'Burg makes 50 HP max (unlikely, probably closer to 30), you're looking at 1-2% of your total output being used for max load on the alternator. Relatively insignificant, but you may get something from it.
