Old 07-05-2009, 04:41 PM   #43 (permalink)
orange4boy
orange4boy's Avatar
The Golden Egg - '93 Toyota Previa DX
90 day: 31.91 mpg (US)
Chewie - '03 Toyota Prius
90 day: 57 mpg (US)
The Spaceship - '00 Honda Insight
My original claim on the the first post here seem to be bearing fruit: Gains from alternator deletion are much greater if voltage is kept above 14.5
Two tanks now under my belt with a big improvement in both most of this difference, I believe, is mostly due to the voltage increase. I did fix an intermittently dragging disk brake so I'm taking this with a grain of salt. On the other hand, I have removed the air dam and grille block I had set up.
Last three tanks averaged 24.15mpg
Previous 5 similar tanks averaged 21.7mpg
a difference of 2.45 mpg. A good 11% gain.
This is all alternator free by the way. This is on top of the gain from the original alternator delete.
I'm still looking for someone with a more consistent commute to bear this out.
Vortex generators are old tech. My new and improved vortex alternators are unstoppable.
"It’s easy to explain how rockets work but explaining the aerodynamics of a wing takes a rocket scientist.
